Diagnostic report 4SNS ICOc-7232.00
I diagnose my imac and it give me this error 4SNS ICOc-7232.00, tried to search in apply but i don’t see which sensor this means? can anyone tell me what this is?
Esta é uma boa pergunta?
Much better! 4MOT is a bad motor HDD is the HDD fan unit iMac Intel 27" (Late 2009-Mid 2011) Hard Drive Fan. We don’t have guide to get to it, but this guide will get you mostly there! Installing iMac Intel 27" EMC 2429 Dual Drive Kit (HDD or SSD) follow it to Step 33, carefully finish disconnecting the cables from the logic board being careful not the damage anything (there are a few fragile components near the sensor lines). With the logic board fully out you’ll have no problem getting to the fan.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 51
4 comentários
Need a bit more here, what is your exact model? Apple has produced many different 27" models.
Look at the bottom of your stand foot to find your systems S/N plug it into here: EveryMac - Lookup let us know what it found.
por Dan
Its 2011, couldn't see where the model number is from this machine, nothing at the back but this is my imac https://support.apple.com/kb/SP689?local...
por Carlo Macias
OK, I can't identify this code, I think we need to try again. Restart your system and run the onboard diagnostics services by pressing the D key. You might want to give us as much information on what your system is doing and if you where upgrading/repairing your system.
Reference: Mac startup key combinations
Make sure you capture the full error and tell us what it is.
por Dan
hi, what i did is replace old HDD with a new one, since my old broke, doesn't read anymore, I did a full diagnose test and I got this error, 4MOT/4/40000003: HDD-1226
por Carlo Macias
