Ir para o conteúdo principal
High performance tablet computer released by Apple on November 11, 2015. Model A1584.
131 Perguntas Visualizar todos
Ipad pro 2015 1st gen Screen replacement questions
I have the Ipad Pro 2015 first gen A1584. In an attempt to replace the battery the screen cracked.
I’m extremely confused on what exactly I should be buying to replace the screen without having to do any soldering work.
https://www.mobilesentrix.com/lcd-assemb...
  1. What screens require the display flex cable and which do not?
  2. Why Do people pay 200$ for a screen that doesn’t include a home button?
  3. Why is this 160$ if it doesn’t include the display flex cable ? https://www.wholesalegadgetparts.com/pro...
  4. Is the display flex cable 100% required?
  5. What if I want a new ipad pro screen without touch id? since touch id is pretty terrible to begin with.
I’m sure ill have more questions after these hopefully get answered.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Ok so when you connect the screen there is 2 cables the digitizer and the display you can check out the guide to learn more.
the reason why people buy screens without home button is so you can transfer the old home button so you can get Touch ID functionality but if you don’t want Touch ID you can buy a new home button.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
OutdatedTech será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 70
