Ir para o conteúdo principal
Modelo A1278 Meados de 2010 / Processador 2.4 ou 2.66 GHz Core 2 Duo
794 Perguntas Visualizar todos
Can I remplace my dead motherboard with MacBook Pro 13" UnibodyMid2009
The motherboard of my MacBook Pro 13" Unibody Mid 2010 is apparently dead.
My MacBook Pro "Core 2 Duo" 2.4 13Inch (Mid-2010) features a 45 nm "Penryn" 2.4 GHz Intel "Core 2 Duo" processor (P8600)
My wife owns a MacBook Pro "Core 2 Duo" 2.53 13" (SD/Firewire 800 - Mid-2009).
It features a 45 nm "Penryn" 2.53 GHz Intel "Core 2 Duo" processor (P8700).
On my Mid-2010 I upgraded the RAM, put an SSD.
So the idea is to remplace the dead motherboard by the one in the Mid-2009 and keep the benefits of my upgrade.
But I don’t know much about compatibilities; would it work ?
Thanks a lot,
Tom
Esta é uma boa pergunta?
Pontuação 0
12 comentários
Hi @appleavatar ,
Read the model number on the motherboard. It should read 820-XXXX. You can replace it with a same one. Why not try to fix it yourself? I am pretty sure you would get support from everyone here.
por
Hi @honakrisi ,
so I can replace a 820-XXXX motherboard with another 820-XXXX, even if not the same but as long as it is marked with the same 820 number at the beginning Correct ? If so, sure I would try to do it myself.
por
No, you need the full model number to match, not just the 820. Almost all Macbook motherboards starts with 820. There are usually 4 or 5 digits follow that actually determine the make and model of your laptop.
What you will find if you try to match it with an older laptop's motherboard is that your display connector will not be aligned, it will have different charger ports, audio connections etc...
por
so what I would like to do is impossible ?
por
Yes it is. They are not compatible with each other.
por
Exibir mais 7 comentários
Adicionar um comentário
1 resposta
Pergunta mais útil
I would focus on trying to get your current board working!
To be clear you’re not gaining performance, sadly loosing! While the CPU clocking is a bit higher, your GPU’s logic is much better in the 2010 model
  • 2009 - NVIDIA GeForce 9400M
  • 2010 - NVIDIA GeForce 320M
Otherwise I would just get a replacement logic board Vs swapping things around 13” Unibody MacBook Pro Logic Board 2.4GHz, Apple P/N 661-5559 for a few dollars more 13” Unibody MacBook Pro Logic Board 2.66GHz, Apple P/N 661-5560
Esta resposta foi útil?
Pontuação 1
4 comentários:
Thanks for the solution and the link :)
I am not sure I feel like invert 225 euros in such an old laptop. You confirm me I cannot put the 2009 logic board in the 2010?
Then I would just have to use the most valuable components I can have in my mid-2010 and put them in the Mid-2009. I guess I cannot reuse the NVIDIA GeForce 320M.
por
@appleavatar - Moving your drive and RAM over to the older 2009 system would be the next best option.
To be clear you can't transfer the GPU as its soldered to the logic board with everything else.
por
Thanks, that's what I did for the moment. what should I do with my logic board ? Garbage ?
por
@appleavatar - Practice soldering & de-soldering ;-}
Some components are the same across the boards worth saving!
If you're good, don't forget to score and accept the answer - Thanks!
por
Adicionar a sua resposta
T P será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 62
