Ir para o conteúdo principal
The second generation 11" iPad Pro was released in March 2020 with the model numbers A2228, A2068, A2230, and A2231.
20 Perguntas Visualizar todos
iPad won't turn on
iPad Pro 11’ won’t turn on. The port is clean. It won’t turn on despite being fully charged. Unable to read diagnostics.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
hello Bernie,
it's been a while and you probably have done it by now. Maybe it will be useful to someone. Unable to read diagnostics because it does not start. If you look at the closer you will find that it is drawing approximately 200mA when you press the power button. This is a problem to be solved in a good repair shop. Probably the damage was due to a defective cable or charger. Similar damage may occur with excessive wear of the charging port (usb-c in this model).
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Bernie Wolter será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 3
Ao todo: 176
