Ir para o conteúdo principal
High performance tablet computer released by Apple on November 11, 2015. Model A1584.
131 Perguntas Visualizar todos
Battery won't charge after display replacement
I successfully completed this guide but when I put everything back together and turn it on, I only see the low battery indicator (even when plugged in) I left it plugged in for several hours but I only ever see low battery. Occasionally the screen will light up with the Apple logo and show the keypad. It even registers a couple of key presses but before I can enter the passcode the iPad turns off. What is going on here?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Double check if the battery connector is properly seated. I recently noticed something similar with an iPhone where the connector wasn’t 100%, but just enough for it to power on, but not to be properly detected in order for it charge.
Esta resposta foi útil?
Pontuação 0
1 comentário:
I took it to a repair shop and they confirmed it was in a boot loop. it's such a common problem with my particular model of iPad they refuse to fix them. I've since given up on it.
por
Adicionar a sua resposta
Brandon der Blatter será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 32
