Ir para o conteúdo principal
Samsung's 5th-generation Android-based Galaxy smartphone was released April 11, 2014. Improvements to the phone include a fingerprint scanner, updated camera, larger display, and water resistance. It is available in four different colors; black, blue, white, and copper.
578 Perguntas Visualizar todos
cannot transfer my memo files
I cannot transfer my Memo files from my Samsung s5 to my pc. I have used all apps when I connect my pc and do a search for .Memo nothing appears
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
1.Connect the Samsung mobile to a PC.
2.A prompt will appear on your smartphone, ‘Use the Connection For’. You need to tap on ‘Transfer Files’.
3.The name of the device will be visible on the ‘File Explorer’. Enter the device.
4.Inside the phone’s directory, tap on the ‘Search’ bar on the upper right side and type ‘Memo’.
5.A folder will show up. Copy all the content of that folder and paste them inside the computer.
Esta resposta foi útil?
Pontuação 1
You can transfer all your memos By screenshooting them and Transfer them to your micro SD Card, then get micro SD card to USB Adapter and your done.Now you can transfer it to your Computer!
Pontuação 0
Adicionar a sua resposta
MIKET será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 7
Duração total: 228
