Changing battery of iPhone 6S with cracked screen
is it dangerous ? or is it possible
Esta é uma boa pergunta?
This should be possible although you will have to be careful while removing the screen. The best method I have found is to cover the broken glass with packing tape, place a suction cup on top of that, and then pull upwards. Sometimes the adhesive around the edge of the screen securing it to the phone body will fight back a little bit and if you continue to pull you may further crack the screen. If you can get a gap between the screen and body you can insert an opening pick and work it around the display to release the adhesive. Try not to pry against the display too much as it could cause further cracking.
Once you get the display up it should be business as usual. iFixit does have a full guide on this repair that should help with any other issues you may come up against.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 21
