Ir para o conteúdo principal
Released September 20, Apple's largest and most expensive 2019 smartphone features a 6.5" OLED display, a triple-lens camera system, and greatly improved battery life. Successor to the iPhone XS Max.
163 Perguntas Visualizar todos
Replacement Display without faceid
I am about to buy a replacement display to determine whether or not the display is causing my device to appear dead. However, in order to be able to return the display if that´s not the issue I am trying to figure out if the display would work without attaching faceid and just plugging in the two display flex cables. Thanks.
Esta é uma boa pergunta?
Pontuação 0
1 comentário
Keep in mind that you disconnect battery cable first then you can disconnect screen flex etc. , after you taken of metal bracket.
por
Adicionar um comentário
1 resposta
Solução escolhida
Yes, to try if the screen is working alright you only have to connect the 2 flex cables from new screen to the logic board. No need to instal frontspeaker.
(Face id is not attached to the screen, so to test new screen you don’t have to transfer frontspeaker to new screen)
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Toby será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 49
