Ir para o conteúdo principal
This product is a 27-inch LED display with a resolution of 2650x1440 pixels released by Apple on July 27, 2010. It has the model number A1316.
78 Perguntas Visualizar todos
Display parts - shocked plug
Hello, I have the 27” Cinema Display and unfortunately a cup of water spilled on my desk and the water touched the power and signal whip. I can only guess that the power contacts shorted against the Thunderbolt plug. The display is dark and no longer responsive. I am looking to repair this display if possible. Does anyone have any advice or know where I can find reliable replacement parts?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
You’ll likely need to open the system up to check the power supply if that got damaged. If you only damaged the cable harness you can replace it 27" LED Cinema Display All-In-One Cable
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Scott Sabin será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 35
