Ir para o conteúdo principal
Released in 1991, this page relates to the SNS-005 model Super Nintendo controller, released for U.S. markets.
Wire Shielding is Pulled out of controller housing
I have a well loved SNES and two original controllers with it, both of which have the shielding of the wires pulled out of the controller shell which I assume just pulled out over time and use. My question is, how is the best way to go about covering the wires again? the best solution I could think of is to buy heat shrink tubing and just ad length to the shielding. But that there also leads to a problem because of the pin connector to the pcb being to large. any ideas or am I over thinking this?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Hello, perhaps you can cut two shrink tubes and hold them with zip ties without heating them.
Esta resposta foi útil?
Pontuação 0
1 comentário:
picture woulda been nice then i could recommend just epoxy it shut from the base. it would stay just be soft on the application.
por
Adicionar a sua resposta
Jon Heliseva será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 7
Últimos 30 dias: 25
Ao todo: 376
