Ir para o conteúdo principal
An Uninterruptible Power Supply (UPS) is an electrical device that provides backup power to critical equipment in the event of a power outage or other power-related issues.
42 Perguntas Visualizar todos
Is it a problem that a UPS replacement battery arrived with no charge?
I have 4 APC UPS’s, three Back-Ups 1000XL’s and one Smart-UPS 1500; every two to three years I end up having to replace the battery when the UPS starts complaining that the battery needs to be replaced. Usually when I buy a replacement battery the battery usually has at the very least a 20% charge on arrival but in the most recent instance where I bought a replacement battery it appears to have a zero charge when it arrived. Not knowing how long this sat with a zero charge, is this something to be terribly concerned about or will I still most likely get 2-3 years of good use out of the battery?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi @normathome ,
Does it start to charge at all?
As you said having zero charge is a concern because it may indicate other problems e.g. faulty battery.
If it starts to charge allow it to fully charge and then check its performance under load i.e. simulate a power failure perhaps, as compared to your other batteries or what you know from experience with them.
You may have to test and fully charge it 2-3 times to condition it again and then check.
Is there a warranty with the battery? Perhaps you should contact the seller anyway and ask/advise about the battery’s condition when you got it.
Esta resposta foi útil?
Pontuação 2
2 comentários:
I'm watching it right now and it's up to an 80% charge so Yes it is charging and my main concern is that I may not get the full life of the battery because it sat for some unknown length of time at 0% charge. The battery does come with an 18 month warranty, so if you think it's a problem then I'll make an inquiry with the vendor.
por
@normathome
As I suggested, check it under load and see if it lasts as long as you think the previous ones did.
I would still contact the seller as getting fully discharged new batteries is not good. Even having a 20-40% charge indicates that they're being maintained before sale or they are reasonably newly made and not old stock
Is there a date stamp on the battery, indicating when it was manufactured i.e. week and year (4 digits) or perhaps month and year? This may give a clue to how old it is.
por
Adicionar a sua resposta
Chris LeFebvre será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 7
Duração total: 855
