Ir para o conteúdo principal
Modelo A1278 Meados de 2010 / Processador 2.4 ou 2.66 GHz Core 2 Duo
794 Perguntas Visualizar todos
After ssd change, the trackpad doesn’t click
After ssd change, the trackpad doesn’t click, and I cant choose disk utility because of it, also Enter doesn’t work! Could anyone help me with this issue? I have Mac OS El Capitan, the ssd I was changing to is Samsung 860 evo 500gb
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
I would first make sure the Trackpad cable is fully seated into the logic board, maybe it got bumped during SSD replacement and got knocked loose.
If that doesn’t work you can try adjusting the trackpad tension screw and see if that helps. You’ll need a T6 to do this. Make a half a turn, place laptop in upright position and then test the trackpad. If it’s not clicking properly make another half turn and test it again. If you over tighten this screw you can break the trackpad so be careful.
Esta resposta foi útil?
Pontuação 0
1 comentário:
Ryan thank you for your reply,
Fortunately enough, I was able to solve my issue using voice assistant throughout reinstalation process, once I was done, I simply recovered my previous settings and it worked as before,
Thanks again for sharing, hope someone will find your reply useful!
por
Adicionar a sua resposta
Адам Хачилаев será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 55
