Ir para o conteúdo principal
The PlayStation 3 (or commonly known as the PS3) is the third home computer entertainment system produced by Sony Computer Entertainment, and the successor to the PlayStation 2. It was released November 11, 2006
778 Perguntas Visualizar todos
Having Y.L.O.D. Repeated Problems
I was wondering If someone could help me with this problem. Recently I got the ylod on my PS3, and I ordered the ylod fix kit from this site, and I used It and was successful with repairing the PS3. The PS3 worked for about 2 weeks then when I was playing Dead Nation the game froze about 10 minutes In and the system shut off and beeped. I then turned the system on the next day and played Wipeout HD, and the system did the same thing, froze 10 minutes In, turned off and beeped. The next time I tried powering the system on I would just get the ylod. So I took apart my PS3 again today, and cleaned out the fan, the casing, etc. and put it back together and It still has the ylod. I was wondering If anyone else knew of any other problems that could be causing this, because when i try powering It on the fan turns on for a second and then the quick ylod comes and beeps. Thanks for reading this and thanks for any advice.
Esta é uma boa pergunta?
Pontuação -1
1 comentário
@oldturkey03, I will try again, thanks.
por
Adicionar um comentário
1 resposta
Solução escolhida
wwesuperstar987, my suggestion would be try to reflow it a second time. The fix is just that, a temporary fix. No matter how high the quality of the kit, it still depends a lot on our own abilities and sometimes a repeat will resolve the issues....again:-) Give it a try and MAKE SURE you have the thermal paste applied properly. Good Luck
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Alex será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 1,011
