Ir para o conteúdo principal
Model A1213 / 8, 16, or 32 GB capacity
216 Perguntas Visualizar todos
My touch is locked and disabled
I bought a 8 gig touch and it's disabled and also locked. how do i unlock it and get it not disabled i don't know the lock combonation
Esta pergunta é pertinente?
Pontuação 3
1 dos comentários
mine is the same way:((
por
Adicionar um comentário
4 respostas
Pergunta Mais Útil
Put it in DFU Mode, then connect it ti itunes, and restore it.
Esta resposta foi útil?
Pontuação 1
4 comentários:
Can you link to directions for DFU mode?
por
Here's a link, it's hard to explain, but there are step-by-step instructions:
http://www.iclarified.com/entry/index.ph...
por
I tryed doing that it starts up with the apple very slow then does same thing stops at disabled again
por
weird, that should work, are you sure you are doing it correctly, it took me a couple tries to do it when i jailbroke my iPod, if you do it right, it will look as if it has a blank screen, and Windows will show somthing like "New device found, iBoot USB Device" then you can open itunes, and it will give you the option to restore it.
por
Pontuação 1
please help me unlock My lpod touch made in 2010 using My gpad 8
Pontuação 0
My 1st generation iPod is disabled for 23,610,434 and I don't know the password and don't have an apple computer. So how can I get into my iPod?
Pontuação 0
Adicionar a sua resposta
murray será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 13,069
