Ir para o conteúdo principal
Repair information and guides for the 2015 Retina MacBook Air. Model A1534
281 Perguntas Visualizar todos
MacBook won't power on
I bought a used MacBook 12 inch(not sure what year) and it will not turn on. I tried the SMC stuff and holding down shift and the power button to no avail. The small lcd on the logic board by the battery disconnect turns on when plugged in, but when turned off it shuts off. I think the keyboard ribbon might need to be replaced not sure. Any help is appreciated!
Esta é uma boa pergunta?
Pontuação 0
2 comentários:
Lets first nail down what you have here. Plug in the systems S/N here EveryMac - Lookup Let us know what it told you.
por
@danj Hi, it told me that it is the early 2015 version, not sure of any of the specs tho.
por
Adicionar um comentário
1 resposta
Problems with the trackpad or cables that route through the trackpad can cause power on issues. If you suspect any of these cables are damaged that could be a good place to start troubleshooting.
Esta resposta foi útil?
Pontuação 0
1 comentário:
@zpl The trackpad cable was cut as far as I know, but how would I go about troubleshooting them?
And is there a sensor anywhere, that shows that there has been water damage?
por
Adicionar a sua resposta
BlackMassata será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 60
