Ir para o conteúdo principal
ML350 2012 Blinkers Randomly Don't Work
I was driving my 2012 ML 350 About a week ago and I tried to turn left with blinkers but the blinkers didn’t work. The “blinker stick” works perfectly fine but the sound when activating the blinkers doesn’t make a sound. When I put Hazard on, it works perfectly fine. I am asking you all because I don’t want to spend money on a repair just yet.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Do the actual blinker lights work? I assume so. If the lights + sound only work with the hazard button then it’s a problem with your blinker stalk. If the only problem is it not making sound when you use the blinker stalk but the lights work normally, honestly I don’t know. Maybe a software issue?
Esta resposta foi útil?
Pontuação 1
1 comentário:
It is the lights and sounds. I'll probably get it for repair soon.
por
Adicionar a sua resposta
Michael Edmilao será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 5
Últimos 30 dias: 23
Duração total: 133
