Ir para o conteúdo principal
Lançado em 3 de março de 2017, o Nintendo Switch é um computador de mão que pode ser jogado na TV ou em qualquer lugar.
702 Perguntas Visualizar todos
Is there a way to fix this damanged ribbon cable port
I was having issues with the right joycon rail, and took it to a mall kiosk… They returned it saying that they couldn’t fix it… I opened the Switch and this is what I saw ;-;
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Has it been opened before you got it? Is the joy con working on that side? To replace the connector, it would need to go to someone who can micro solder. You may be able to get away with putting a piece of thin plastic, or paper in between the connector and flex cable to help make a better connection.
Esta resposta foi útil?
Pontuação 0
At the time of writing (11th of jan) here would be a replacement connector: Ribbon cable connector for Switch Joy-Con SL SR rail
Pontuação 0
Adicionar a sua resposta
Cora Mo será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 7
Duração total: 791
