Ir para o conteúdo principal
Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White.
3305 Perguntas Visualizar todos
Home Button not working
Perhaps someone can help me. I just disassembled mine and got to the very end. I can't see anything wrong with my home button. The Apple tech said it was just some prongs that needed to be bent back, but I don't see anything like the prongs. My home button stopped functioning completely. Should I just replace the entire home button and ribbon, or should I replace something else, or are there really a couple of prongs that need to be bent back?
Esta pergunta é pertinente?
Pontuação 0
Comentários:
Thanks. That worked. Extremely time-consuming and by far the most difficult task I've ever completed, but it works perfectly.
por
Adicionar um comentário
1 Resposta
Solução escolhida
I just replaced mine, there are no prongs. It's the entire home button and ribbon that need replacing. It's all one piece.
Esta resposta foi útil?
Pontuação 1
Comentários:
Thanks. That worked. Extremely time-consuming and by far the most difficult task I've ever completed, but it works perfectly. (I commented on this above, before it was an answer, so it shows up twice.)
por
Adicionar a sua resposta
jkgarrett17 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 828
