Craftsman T110 Brand New Clicks but won't crank
I have a brand new Crasftman 42” T110 that has a manufacture date of 06/2020. It has run perfectly so far, but this past weekend I changed the oil and fired it up. Since I had it out and running already I decided to mulch some leaves. After passing over the leaves it clogged the blade and killed the mower. I backed it up raised the deck and fired it up. The blade clogged again even at the higher setting and then when I went to start it again all it does is make a loud click coming from the deck area. There is no crank in the engine at all. Battery is good, I tried a new fuse, the solenoid appears to be working fine although I haven’t taken it off and tried to replace it. I checked the fuel line and spark plug and it has brand new gas in the tank. Any ideas what might cause this problem?
Esta é uma boa pergunta?
