Ir para o conteúdo principal
Toshiba's laptop with 4GB storage and an AMD A10-8700P Quad-Core APU processor.
5 Perguntas Visualizar todos
Toshiba laptop screen won't go further than logo start screen.
Toshiba Satellite. Think was this model. Not sure of model as sticker has fallen off .
I was getting no boot etc..please restart etc.. I have switched on again with the laptop connected to the mains and been pressing F12 and got the boot menu. It's on Windows 10.
There's the list of HDD/SSD, USB, ODD, LAN.
And below ENTER SET UP . Not sure what I need to do now.
Esta é uma boa pergunta?
Pontuação 0
1 comentário
If you can get to the BIOS, try resetting and also try booting up from a USB.
por
Adicionar um comentário
1 resposta
Solução escolhida
You didn’t specify how far you got after swithcing it on.
You could try Performing a Start-up Repair:
The first thing you can try is booting into the recovery environment, if possible, and then performing a start-up repair.
To access the recovery environment, turn your computer on and off three times.
While booting, make sure you turn off the computer when you see the Windows logo.
After the third time, Windows 10 will boot into diagnostics mode.
Click Advanced options when the recovery screen appears.
 Click Troubleshoot.
 Click Advanced options.
 Then, click Start-up Repair.
If you can’t get this far your hard drive may be corrupted
If so try booting with a USB flash drive with with the Windows installation files on it, as drmdolfan suggests.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Jennifer Dawson será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 5
Duração total: 654
