Ir para o conteúdo principal
Why won't my MacBook boot up.
I have a 15 inch non unibody MacBook pro that won’t turn on. It originally turned on when I got it last year no problem. Then it started to take longer and before harder to turn it on. I recently took it out of storage to turn it on and can’t get anything out of it. Last time i had to do something with the ram when it was plugged in to turn it in. Is it the pram battery?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Yes its possible your pram battery failed, also make sure your ram you put in was compatible( 667mhz ddr2 pc 5300 or 667 MHz DDR2 SDRAM). Try a pram reset or smc to see if it comes back on.
Hope it works,
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Owen Hewitt será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 10
Ao todo: 225
