Have error code 'Er rF' on a Kenmore Elite model 795.74023411.
Most responses involve ice on the cooling system. I have followed all the instructions, exposed the tubes…no ice. Anyone else with this issue?
Esta é uma boa pergunta?
Pontuação 0
3 comentários:
Hi @mwpjs ,
What problems are you having with the refrigerator?
It seems strange that the error code that you posted doesn't appear in this list of error codes for your model range.
por
Food in the deli/produce/meat drawer is all freezing. And it doesn't cool as well when the code is up, otherwise nothing. It does sound as there is water in the back although i have seen nothing to indicate such. I do not have the ice maker connected so this isn't a factor. I can kill power, reset the temps and within the hour the code is back up.
por
Hi @mwpjs ,
Don’t know your refrigerator but looking at the parts there are two temperature sensors in the refrigerator section (part #610C & #610D - case parts diagram) so I would start with those as these signal to the control board to stop/start the cooling in the refrigerator depending on what temperature has been set, so the drawer section shouldn't be getting cold enough to freeze.
por
Adicionar um comentário
