iPhone 11 pro not included
Hello, the phone is obviously dropped and does not turn on. what is its problem circuit board or battery.
Esta é uma boa pergunta?
If you did have vibrate on mute enabled, you can perform a quick and easy test. Simply flip the mute switch. If it vibrates then its obviously not the battery because it is powered on. You could also try to call your number. If it rings then again, it’s powered on. If you dropped it you most likely damaged the OLED panel.
Esta resposta foi útil?
Thanks for the info will work. ;)
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 5
Duração total: 261
2 comentários
have you tried a replacement screen at all?
por Jade Richards
I'm not I thought it was the battery
por dimit1r89
