Ir para o conteúdo principal
Movies, music, multimedia in your home. Use our guides to repair home entertainment devices from surround sound A/V receivers or conventional stereo receivers to power amplifiers, preamplifier, speakers, and iPod/Bluetooth speaker systems.
4593 Perguntas Visualizar todos
Required wattage for Labtec LCS-2408 subwoofer adapter?
What wattage is needed for this 15V negative tip adapter?
I bought this computer subwoofer used, without an AC adapter or manual. It is marked for 15V, negative tip, but gives no indication of wattage or amperage. Labtec's official site does not support this item any longer. Can anyone offer advice?
Esta é uma boa pergunta?
Pontuação -1
1 comentário
This question was migrated from http://meta.ifixit.com/Answers.
por
Adicionar um comentário
1 resposta
Solução escolhida
It is more important to get the amperage right. The calculations that I have for my power supplies are based on the wattage of the device. Amp=Watts/Volt So lets assume your subwoofer has 30watts and you know you need a 15V power supply 30/15=2amp (2000mAmp) The power supply I would be looking for in this case would be 15V2000mA or higher on the amperage, since it is your device that will draw the amperage. Hope that makes sense. Good Luck.
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Stephen Hamilton Wright será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 718
