Can the iPhone 4s camera be installed in the iPhone 4?
Just as the tittle says.
Can the camera be installed on the iPhone 4 to "upgrade" the camera?
Esta é uma boa pergunta?
Just as we expected, the connector for the camera on the iPhone 4S is different than the connector on the iPhone 4 (CDMA and GSM). This means that you cannot "upgrade" your camera in your iPhone 4 (or downgrade your 4S if for some odd reason you can't handle the 8 megapixel camera). The iPhone 4S connector has more pins. Even if it did fit, I don't think it would work anyways.
iPhone 4S:
iPhone 4 (CDMA and GSM Side-By-Side):
Guia
Nível de dificuldade:
Moderada
Guia
Moderada
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 3,243
3 comentários
I think it will be different since they changed it quite a bit. We'll check that out when we do our teardown.
por Scott Head
agreed, too early to tell. from what I know about apple components, most likely not.
por hectordtruong
Do you know who the manufuacturer of the camera is? The world is waiting...
por bob cooper
