Ir para o conteúdo principal
Hybrid laptop/tablet manufactured by Microsoft. Released November 2017.
35 Perguntas Visualizar todos
After replaced Keyboard battery don't charging
Hi 4 all .. i replaced keyboard battery for my surface book 2 model 1832 .. with same code of old dead battery but the new battery don't charging … how could solve this problem please …
  • I tried uninstalling the battery drivers not work too.
  • When turn device on and the charger connected to it .. device work normally
Esta pergunta é pertinente?
Pontuação 0
Adicionar um comentário
1 Resposta
Solução escolhida
Since you replaced the battery make sure it’s plugged in securely and the black connector is pushed all the way into the port on the mainboard. It may be the ac adapter/charger you are using, make sure the charger is fine as well.
Esta resposta foi útil?
Pontuação 0
1 dos comentários:
@angeld
I check the connector many times and test charging with two ac adapters
But same problem no charging ..
Surface work with direct power only ..
por
Adicionar a sua resposta
Gaith será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Duração total: 153
