Ir para o conteúdo principal
Known as the ''PS2'', it is a sixth-generation video game console first released by Sony in Japan in March 2000. The United States saw it later in 2000 with the SCPH-30000. Repair of this device requires only common tools, but can get tricky.
199 Perguntas Visualizar todos
Disk tray won’t close
I just received my dads old ps2 and the disk drive will open, but when prompted to shut it does so, then opens back up. It does this twice then just stays open.
i took it apart to clean it, and am hoping the problem will fix itself. Knowing it wont, what should i do?
Esta é uma boa pergunta?
Pontuação 2
1 comentário
I have the same problem I’ve been trying to figure out
por
Adicionar um comentário
1 resposta
Solução escolhida
Hi Logan,
I saw this once as I had one which has this issue too.
I replaced the drive belt (replace this all the time actually), but at my case this was due the tray which was not seated properly. Could you check this? Perhaps you need to take it out, clean it and put it back in.
Note: Some models have additional screws installed to hold the disk tray at place!
Esta resposta foi útil?
Pontuação 3
Adicionar a sua resposta
Logan Elias será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 18
Últimos 30 dias: 48
Duração total: 3,686
