Ir para o conteúdo principal
Repair guides and support for 21.5" Intel iMacs by Apple.
2131 Perguntas Visualizar todos
LED 1 illuminates momentarily when the power cable is applied.
Cannot answer with a solution I’m afraid but I have an A1311 whereby the number 1 LED illuminates momentarily when the power cable is applied.
Have swapped the PSU already but still unresponsive.
Any advice?
Esta é uma boa pergunta?
Pontuação 0
3 comentários:
Check secondary voltages for short circuit.
por
Paul Scarbro give us a bit more to identify your iMac. An EMC number or serial number so we can identify which one of the 9 different models you have.
por
Paul Scarbro - We really need to know which model you have!
If you don't know locate the systems S/N on the bottom of the foot and plug it into here: EveryMac - Lookup Then tell us which one.
por
Adicionar um comentário
1 resposta
Paul Scarbro right now it means your system does not power up. You replaced the PSU now time to check further. Check these
LED Startup Sequence
LED #1 = Power available.
If no LED is visible:
• First disconnect the AC cable from computer, then reconnect it to reset the LED status,
in case computer was correctly shutdown and AC was kept connected since
• Verify AC source
• Verify known-good AC cable is connected
• Verify cable connection between AC inlet and power supply
• Verify cable connection between power supply and logic board
• Verify power supply
LED #1 + LED #2 = Power available, and system is powered on.
If second LED is not visible when power button is pressed:
Verify power button connection to logic board
• Verify power button functionality
• Verify logic board
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Paul Scarbro será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 24
