Where is the egr valve located on 1998 mazda 626
where is the egr valve located on 1998 mazda 626
Esta é uma boa pergunta?
It's underneath the throttle body. Round in shape, has an electrical connector for the EGR lift sensor and a vacuum line is connected to it. Check the attached diagram. I would definitely clean it first and make sure that your vacuum lines do not have a leak before replacing it. No a common part that wears out. Hope this helps, good luck.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 4,996
1 comentário
Thank you for accepting my answer and good luck to you.
por oldturkey03
