Ir para o conteúdo principal
65" Toshiba TV LCD with LED backlight Model number 65L5400U
1 Perguntas Visualizar todos
Good backlight and "Toshiba" displayed on power up, then unresponsive
Hi,
Judging from the fact I had to create the device page, I am not super optimistic in this being solved, but
I bought this TV, And it wouldn't even turn on. The standby light would come on When plugged into the wall however nothing was displayed on the screen and the backlight would not even turn on. After ordering a repair kit from thetvguy.com and replacing the main board powerboard, backlight driver board, and another smaller auxiliary board (off of the main board) the TV would boot up the backlight would turn on. The Toshiba logo is then displayed for brief moment before the ENTIRE screen (literally nothing at all) turns black with the backlight still on. None of the buttons on the main board are responsive. After some digging I figured that the issue may be the T con board so I bought a replacement and just put it in. Based on the fact that I'm posting here you can probably guess that it made no difference.
Any input at all as to what might be causing this issue would be greatly appreciated and I would be more than happy to answer any questions to help get this resolved.
-Grant
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
Hi @grant_mlack ,
What is the model number of the TV?
Toshiba is not helpful as far as service manual go etc as they don't want you to know.
just asking as you didn't mention it, but did you try different signal inputs or input types e.g. coax, HDMI, Component video and also can you see the TV menu screens at all? I realize that you said that none of the buttons on the mainboard were responsive but I'm not quite sure what you meant. Has the mainboard got buttons or did you mean the TV (or remote control) control buttons then?
Since the TV gets to the logo stage, however briefly it appears that the screen is OK and also from the mainboard to the screen as the logo is in the software on the mainboard.
Maybe search online for "Toshiba (insert TV model number) firmware" and check if there is any and if it can be manually installed in the TV.
I don't know about Toshiba but with other makes the firmware can be installed via USB without having to go through the menus. Simply plug in the USB with the firmware and turn on the TV. It checks the USB port on startup for a file with the correct filename and if there loads it and installs etc. With some other makes however you need to navigate through the menus to do this so obviously no good in your case if it is the same. Still worth a look anyway.
Make sure that you get the correct firmware as installing the wrong firmware can brick the TV.
Although since you have replaced the mainboard the firmware should be OK.
Again just asking did you verify that the mainboard is compatible with the TV model?
Esta resposta foi útil?
Pontuação 1
8 comentários:
@jayeff my apologies about the model number, I thought I had the TV linked to the post. The TV is model number 65L5400U, its a 65in Toshiba.
I have tried both HDMI ports on start up, but I will test the other inputs today and get back to you.
On the ifixit page for the TV (model 65L5400U) I uploaded some images of all the boards and the TV manual. There are 4 buttons on the Main Board that correspond to Power, Volume up, Volume down, and Channel/Input (from top to bottom. Basically, none of those buttons do anything when pressed. After being plugged in, the TV boots itself up, displays "TOSHIBA" in red with a black background, then sits at a totally black screen with no display at all (backlight still on) I am unable to access menus, and no indication of volume level, channel number, or anything else is displayed.
I also purchased the exact components that were in the TV originally
I searched for the firmware, but was unable to find any.
Thanks for the input, and I'll get back to you ASAP!
por
@grant_mlack
My apologies to you.
I saw the device information and made a wrong assumption as a lot of posts here just pick the nearest device to what they have. I didn't notice that it was created by you, not even though you said it in your post. Again my apologies
No images or audio but with backlight makes it seems as though the mainboard has problems and has shutdown i.e no power or has not fully completed the power on boot process but you have changed both the power board and the mainboard
Did you change all the boards that you changed all at once or one at a time?
Have you tried swapping back original individual boards one at a time and checked? Not sure if this is good advice if there is a fault which is damaging a good board when it is inserted so that the fault is still there regardless.
As I said I don't know Toshiba so just trying to get a handle on how it works so that things can be tried to narrow it down.
Screen seems to work because logo seen OK, backlights work so LED driver board OK so presumably power board works OK for that, mainboard starts up displays logo then nothing not even audio so just not a video problem. Do you know the history of the TV?
por
@jayeff
Unfortunately i do not know the history of the TV. I picked it up for next to nothing and figured it would be a fun project to fix. Now I'm way too invested. It was in a storage unit for some time apparently. (I know I was asking for trouble haha)
Just tried all the inputs and no luck
I swapped out each board one board at a time and it was when I replaced the main board that the screen actually turned on, i.e. Toshiba logo and backlight.
Leads me to believe everything downstream of the mainboard is fine.
I have not gone back and tried the originals though. I'm going to do that right now. Might try the old psu with the new main board?
I just wish I knew more about what to look for on the main board. I trust my abilities with soldering and such, but when it comes to diagnosing the issue I'm just lost.
I feel like you might be right about the boot of the main board not completing properly, I just don't know how to test that.
-Grant
por
@jayeff
Just swapped boards around. Psu and all other boards (except the mainboard) seem to yield the same results between old and new.
Feeling more and more strongly about the Mainboard being the issue
I tested the test pins on the main board coming from the PSU and they all seem to have stable voltages at the correct values. I can add more photos if needed as well.
-Grant
por
Hi @grant_mlack
The board shown in the 2nd last image seems to be the board that all the testing is done on if you have the right test equipment and you know what you're testing for. It shows points such as TMS, TDCK, DEBUG, TCE and TCK but I have no idea what they mean or what they relate to, but the term "debug" is common when testing devices.
The LED driver board (assume that it the 4th image down) is the only one besides the power board that seems to have fuses on it so again no joy in testing the other boards for known voltages at specific points (although I note that you tested voltage to the mainboard OK.)
Can only think that you could try checking the cables between the boards for continuity of each wire in case of fracture or even corrosion in the ends that connect.
That's about all that I can think of at this stage, that you haven't also tried.
Sorry I don't think that I know what to try next that may help you.
por
Exibir mais 3 comentários
DEAR SIR,
Good backlight and "Toshiba" displayed on power up, then unresponsive MEANS YOUR MAIN MOTHER BOARD HAS A PROBLEM
1.YOUR T CON BOARD, PSU BOARD IS OKAY AS TOSHIBA LABEL WAS ON DISPLAY IN STARTUP
  1. GET AN USED OR NEW MOTHERBOARD OF model 65L5400U , REPLACE THE PROBLEM ONE AND START IT UP, IF DISPLAY OK THEN THE FIRST THING YOU DO CHECK THE WIFI SETTING, RESET AND DOWNLOAD THE SUITABLE FIRMWARE FOR THAT MODEL........AFTER THAT YOU GO TO TO RESET FACTORY AND RUN THE PROGRAM
  2. THE SOFTWARE WILL INSTALL ITSELF AND THEN LATER U MUST TRY YOUTUBE APP.....IF IT IS RUN WELL THEN YOUR TV SHOULD BE FINE....
Pontuação 0
1 comentário:
or fine the motherboard of 55L5400U, used it as replacement if the motherboard 65L5400U could not be found
por
Adicionar a sua resposta
Grant A Mlack será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 9
Duração total: 756
