Ir para o conteúdo principal
PS4 Controller model CUH-ZCT1. Released in November 2013 by Sony Computer Entertainment, this six-axis, 3.7 V lithium ion battery controller is uncomplicated to repair. (NOTE: Teardown guide is NOT for this model)
387 Perguntas Visualizar todos
Ps4 controller won't turn on or connect unless I reset it
Hello,
My ps4 controller has a problem
I used to connect it to my pc via bluetooth and everything seemed ok until last week
so i connected it to my ps4 and played with it then i put it into rest mode
but the next time i pressed the PS bottun it just kept flashing…it didnt connect automatically, and when the flashing stopped it didnt turn on when i pressed the PS button
so every time i wanna use it i have to reset it or hold the PS button for 10 seconds and then connect it to my ps4 with usb, then it recognized the ps4 and works either wired or wirelessly…
so how can i fix it? im thinking there might be a settings issue
i dont know
thats why im here
sorry about my broken english
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
anyone? i couldnt fix it using the above method
por
Adicionar um comentário
1 resposta
Hi!
Sounds like it’s searching for your bluetooth device instead the PS4.
Did you removed it from the settings (bluetooth list) at your PC?
This will come in handy, everything about how to do a (hard) reset for the Dualshock 4: https://www.lifewire.com/how-to-reset-ps...
Esta resposta foi útil?
Pontuação 0
3 comentários:
thank u for ur answer...yes its no longer connected to my pc...i will try to hard reset it and post a reply on whether it worked
por
it didnt help
the problem is still there
por
This sounds more likely a software issue instead hardware.
Could you try this?:
https://www.youtube.com/watch?v=1KUUxPO2...
por
Adicionar a sua resposta
Alireza Gh. será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 13
Duração total: 1,635
