Ir para o conteúdo principal
Repair, troubleshooting, and disassembly guides for Netgear routers.
40 Perguntas Visualizar todos
How to turn an old netgear router in to an ethernet hub
My google router only has one ethernet port, but i have way more than one device I would like to use. I have an old netgear router, can I turn it into an ethernet splitter/switch to use my tv and computer with?
Esta é uma boa pergunta?
Pontuação 0
4 comentários
Hi
Let us know the exact model of your google router and netgear router too, it depends .... e.g. like login to netgear router, disable dhcp server, and if need wireless, remains or set the settings as in or disable it when not necessary. connect from the google lan to either port 1 - 4 (i suppose there is for your netgear router)
por
Ok will do. I will get those to you
por
Netgear router- wireless g router WGR614v9
Google router- model a4rac-1304
por
Not the nest 2nd gen. These are not mest products, they are google. Heres a link to the google ones. https://www.dell.com/en-us/shop/google-g...
por
Adicionar um comentário
2 respostas
Pergunta mais útil
Net gear routers should have an option that allows you to configure it in AP Mode or Access Point Mode. After it’s in access point mode, you can plug it into your google router and use it as a splitter and access point both.
Esta resposta foi útil?
Pontuação 1
1 comentário:
How do I access that
por
Hi,
Here’s the user manual for the Netgear router. Go to the Wireless Repeating Section p.4-10
Pontuação 1
Adicionar a sua resposta
Dylan Devries será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 11
Duração total: 1,319
