Ir para o conteúdo principal
Wi-Fi only version of Apple's 2nd generation iPad Air. Model A1566.
Replacement screen not sitting flat iPad Air 2
I replaced digitizer everything works but the left side won’t lay flat and stick like the rest of the edges. Any ideas?
Esta é uma boa pergunta?
Pontuação 1
2 comentários:
Is there any damage to the corners or sidewalls?
por
No damage it feels like something's is underneath it not allowing it to go down
por
Adicionar um comentário
1 resposta
Aftermarket screens are required to have thicker “bezels” than apple screens because of some copyright thing. Any screen that isn’t apples has to be thicker. I’m sorry but you can’t get around this unless you want to pay apple $100 - $600 to “replace the screen” on your device. Apple usually doesn’t even hassle with replacing the screen and they just send you a new device. I hope i was helpful in answering your question!
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Melissa Witty será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 180
