Why did front camera fail?
I replaced the front screen and the camera worked for about a month or so, but then failed and only shows a green square. Do I need to replace the entire assembly again?
Esta é uma boa pergunta?
Was the front camera pre-installed with the replacement screen? If so, it’s not uncommon to have poor quality “small parts” installed in these types of screens. If you still have the original camera, I would put it back in to see if that solves your problem.
If you transferred over the original camera, then you may have accidentally damaged the flex, not enough to cause immediate failure. In that case, open up the phone and inspect the flex and connectors to see if there is any damage (tears, kinks etc.).
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 29
