Ir para o conteúdo principal
Repair guides and support for top and front loading Whirlpool brand washers.
425 Perguntas Visualizar todos
loud knocking during the spin cycle.
I have a similar problem whit my duet front loader. There is a loud knocking during the spin cycle. however if you place your hand on the door it stops. Any suggestions?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
@Bruce Rogers if your hearing it during a spin only, then it’s probably the rear bearings. Not the easiest repair. Both the tub and basket have to be removed. To do that requires almost a complete tear down of the unit. Most companies call this a 2 man job. I call it a 1 woman job with all the help I can get. It’s time consuming and pounding bearings out is never fun.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Bruce Rogers será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 35
