Why is my hard drive not showing up?
I recently replace the optical drive in my 1.5GHz Mac Mini with one that I bought from ifixit.com. After re-assembling and powering up, the hard drive was not seen. Thinking the drive died I went out and bought a new one and installed it. Still no drive showing up. I am thinking that maybe the interconnect board went bad? The optical drive works fine, only any hard drives hooked up are not seen. How can I tell if it's the interconnect board or something worse?
Esta é uma boa pergunta?
1 comentário
I ended up taking out the interconnect board and noticed some of the pins on the SATA connector were crooked so I played with them a bit and got it working again. I installed snow leopard on the newer bigger drive and used migration assistant with the old drive in a USB enclosure to migrate in all the data. It seems the SATA connector on the 2006 interconnect board is very poor. Is their any newer revision that is better made and compatible?
por brandtdaniels
