The sensing blink light is still flashing
I've done everything step by step as shown up top and the sensing blink light is still flashing what should or else I do
Esta é uma boa pergunta?
@Bryen Aareon If the only light blinking is the sensing LED then the sensor has found an issue in the basket/drive This could be a bad shifter, worn hub assembly or an item of clothing that managed to get between the inner and outer tub. The inner tub engages the clutch by dropping down. This washer checks the position of the basket at the beginning of wash before it fills. That’s the noise you hear the first few minutes after you press start. Flashing sensor means it detected a problem with the positioning of the basket.
Esta resposta foi útil?
Últimas 24 horas: 7
Últimos 7 dias: 28
Últimos 30 dias: 117
Duração total: 4,176
