Ir para o conteúdo principal
Lançado em 3 de março de 2017, o Nintendo Switch é um computador de mão que pode ser jogado na TV ou em qualquer lugar.
Nintendo Switch won't charge
Hi, my son’s Switch won’t turn on or charge. I replaced the battery, and in doing so, damaged the SD card reader, so I replaced that as well. Since the new battery came with some charge, I can be sure it is not a display issue, as the display worked, but on connecting the Switch to the official charger (directly - no dock) there was no indication that it was charging. I have attempted to charge it over several days with no effect.
Other than the battery, what other replaceable points of failure could there be? And how would I best test them to isolate the issue?
Esta é uma boa pergunta?
Pontuação 2
1 comentário:
Not sure if you need help anymore but do you have a multimeter handy?
por
Adicionar um comentário
1 resposta
Here is a list of components that can cause a Switch to not charge:
Battery
Charging Port
Charge Chip
Various other chips, diodes, resistors, capacitors, etc. on the motherboard
As Raffi said, you would need a multimeter to check to see if these were bad. You would also need a hot air station, flux, solder, and a soldering iron to fo these other motherboard-level repairs.
Another thing you could do is to replace the motherboard. However, a new motherboard will cost about $180.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Andrew Sharpe será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 20
Ao todo: 598
