Ir para o conteúdo principal
The PlayStation 3 (or commonly known as the PS3) is the third home computer entertainment system produced by Sony Computer Entertainment, and the successor to the PlayStation 2. It was released November 11, 2006
781 Perguntas Visualizar todos
Why can't my PS3 enter standby mode?
When I power on my PS3 40GB (CECHJ04), it seemingly acts fine, but there is no signal getting to the TV. I’ve tried changing TVs, HDMI cables, component, nothing. Tried to reset the output settings by holding power until the second beep, cleaning the inside, all for naught.
After trying to get it back running for a few days, I also noticed that there’s no red light whatsoever. It just doesn’t glow red (or yellow) and it can’t enter standby. Atleast I am assuming so, as I can’t see anything changing on my TV. Also, it doesn’t turn off by itself, even after hours on end. The fan is just spinning quietly, the LED is solid green and the disc drive functions properly.
So, should I even bother buying a new HDD, applying new thermal paste or changing the motherboards battery? I don’t wan’t to use it myself, just want to fix it because I like to repair “retro“ consoles.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
that’s a power state feature, the internal power supply or main board may have debris shorting or limiting it’s use.
Esta resposta foi útil?
Pontuação 1
1 comentário:
Thank you.
Removing the debris might be enough then. Are there more potential causes for this state?
por
Adicionar a sua resposta
Ulrich será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 4
Duração total: 163
