Ir para o conteúdo principal
I have change everything and still don't work
Hello, I changed all the parts that can be changed other than the motherboard and I really do not understand why the phone does not want to open. I changed the LCD first and nothing more. the frame has been twisted / bent at the loading port.
Esta é uma boa pergunta?
Pontuação 0
2 comentários
what do you mean the phone does not want to open? what are you trying to fix?
por
I have change all part inside the phone . the screen was dead so I have change it but after that he doesn't want to open (on/off) anymore . i just want to be able to power on the phone
por
Adicionar um comentário
1 resposta
Solução escolhida
Hello, it’s probably a dead motherboard, open iTunes in your PC and plug your phone, if you see a notification of a connected phone so this means that your iPhone is running fine but not displaying anything, which means that either your screen is broken or the display port (or anything related to it) on the motherboard is damaged.
Wait at least 5 minutes after you plug the iPhone, to be sure that the battery is charged enough (in case if it’s discharged) to run the phone.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
FIX ton Phone será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 54
