I have no fuse box in engine compartment 1992 surburban 5.7
I have a fuse box under my dash but the one in engine compartment is not there
Esta é uma boa pergunta?
Hi,
According to the 1993 owner manual (see pages 6-70 & 6-71 also 6-44)there is only the one fuse block, located in the instrument panel on the driver's side.
I realize that you said for a 1992 model but the ‘93 model is the same generation (8th Gen. 1992-1999) so it should be similar
Esta resposta foi útil?
Thank you for answering I was just troubleshooting I don't know why my truck will run like a dream then I'll park it come back and blah it doesn't have a muffler or cat so already loud but it seems to get much louder and performance is s garbage that's how I know how my day is going to be when I start it then out of nowhere my trans dipstick falls out and I'm leaking all my fluid .
Hi,
Don't know your vehicle but this link may help to find out what's going on.
If not search online for similar info specific to your particular make and model. Your vehicle is pre-OBDII specs but maybe has OBD. Also sounds as though the engine is shaking too much if the dipstick is falling out - engine mounts or maybe faulty dipstick not sitting tight enough?
Just some ideas
Post photos of engine compartment area, maybe someone can give you an idea of what is going on with your vehicle.
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 8
Duração total: 259
