Pular para o conteúdo principal
Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White.
3270 Perguntas Ver todas
iPhone 4 cant find wifi hotspots
hello,
have here iphone 4 after lcd replacement cant find any wifi signal.
have solution for this?
Respondido! View the answer Também tenho esse problema
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
Kit de Reparo de Bateria do MacBook
A partir de $69.99
Buy Now
A partir de $69.99
Buy Now
5 Soluções
Solução escolhida
iPhone 4 Display Assembly Replacement take a look at step 14...clearly states the reason for most loss of wifi signal after repairs..check your screws are in right (step 13 has a good tip) the clips are on the metal cover etc. That 4.8mm screw is important and so is the area that holds it in, take a good look for any damage there. You also need to make sure you have cleaned greasy fingerprints off your metal work.
Esta resposta foi útil?
Pontuação 1
Comentários:
+ excellent answer as always and very descriptive without guessing....;-)
por
after reading everyone's drama's over their loss of wifi I am super doooper careful with the iphone 4 repair...hate it!
por
Wifi peroblem Solved Iphone 4
I got problem long time with iphone , not finding wifi signals it not was to close to the router!!
checkthe photo of that piece and see if you have lost the metall piece fromthat,, if so find it or replace and u will get back wifi.
Pontuação 1
Comentários:
That solved my problem
por
Sounds like the phone was assembled incorrectly after repair. One of the cable under the screen is possibly not connected properly
Pontuação 0
Comentários:
Spot on. There are a lot of connections and tiny details that can be overlooked when re-assembling...or even connections that you swear you reconnected but just didn't reconnect fully. Try cleaning connections as you recheck everything.
por
A piece of aluminum can do the trick too :) just fold aluminum so it is approx. 8mm x 4mm x 1-1.5mm and place it under the screw and the round gold/metal piece right next to the screw.
Pontuação 0
Reply to:
Can you provide a picture? Does this completely repair your WIFI signal?
I posted WIFI Antenna 4.8mm Screw (Lost "nut" for it)
In one important post above it says, "That 4.8mm screw is important and so is the area that holds it in." I think I lost part of the "area that holds it in" and am now getting no WIFI signal.
Pontuação 0
Adicionar a sua resposta
michael será eternamente grato(a).
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Todo: 2,181
