Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Loja
Announced October 22nd and released November 12th, 2013. The iPad mini 2, also known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
434 Perguntas Visualizar todos
Screen adhesive iPad mini 2
Hi, is it ok to use b7000 glue to adhere the screen down? I found using the adhesive strips don’t hold up to well over time. I heard the adhesive strips by bowler tech is good but since I have b7000 sitting here I wanted to see if that will be good enough.
Esta pergunta é pertinente?
Pontuação 0
Adicionar um comentário
1 Resposta
Pergunta Mais Útil
Yeah the pre-applied adhesive strips generally aren’t enough I put B7000 liquid glue on the corners.
The bottom right definitely needs it because the ribbon cable for the digitizer pushes the screen up overtime so some liquid glue there will help.
Esta resposta foi útil?
Pontuação 3
Comentários:
Ok perfect thanks.
por
Adicionar a sua resposta
John Nguyen será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 38
