Why there’s a blue Tint on my iMac Screen?
Hello I’ve recently upgraded my HDD in my 20 inch 2009 iMac’ but after replacing everything, the screen took a blue tint, and I don’t know how to resolve it, thanks for your Help
Esta é uma boa pergunta?
@Taha Khetib - Did replacing the cable fix things?
Esta resposta foi útil?
For the moment I'm still waiting to receive the LVDS cable, I will let you know as soon as I receive it !
So i’ve tested with a new cable but nothing, screen is Still blue
@Taha Khetib - I think that points to a bad T-CON board that’s the logic board sitting on the backside of the display assembly. You might be able to scare up one but you’ll need to get to yours to properly ID which board you have.
Oook I see, if i purchase a new display will it be ok ?
@Taha Khetib - Yes, that should fix things!
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 104
What does an external display look like?
por Dan
@I don’t have any external display with DisplayPort and any adapter, Can AirPlay count as a external display or iPad with a software like XDisplay ?
por Taha Khetib
Sadly, that's using a remote connection to the system, not accessing the GPU logic directly.
por Dan
@danj I see, but how Can i test the GPU, and know if it's a GPU problem or this is the screen ?
por Taha Khetib
Using an external monitor is all there is.
por Dan
