My wifi not turning on why?
The wifi not turning on at all I factory rest the phone didn't work and is the wirless charger is it the same part for wifi if not how does it look like I want to replace new one. Thank you
Esta é uma boa pergunta?
Pontuação
0
Maybe you have damaged the flex cables? It seems that you had opened it earlier on, going by a previous post. It may be with replacing the flex cables and the wifi antenna, and see if it works then. In regards to the wireless charging, you will neeed to replace the QI coils.
por Esa Rashid
