iMac only white screen with chime
This iMac 17” 2006 when powered on has chime but only white screen, any solutions?
Esta pergunta é pertinente?
Generally a white screen issue is related to a failed hard drive.
Insert your original system installation DVD and boot holding down the “C” key. If you do not have that disk you need to have a system compatible external USB source to boot from. Another alternative is using another comparable MAC in Target Mode.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 38
Could you try the suggestions from this: https://blog.macsales.com/40844-how-to-r...?
por Jonas A.
