Can't Detect Bootable USB
I have a Macbook Pro late 2011. I wanted to wipe it to give to another user.
I wiped the drive in order to reinstall the OS. It had Yosemite installed before the wipe. I followed a guide which instructed me to wipe the drive and reinstall from the utilities menu. This gave me an error so I tried to reinstall using the command that installs the latest OS compatible with my device. This downloaded the Lion OS which then gave me an error of not being able to download required components.
I then created a bootable USB with Yosemite, making sure it was formatted for GUID Partition Map, and my laptop could not detect the USB when booting while holding the option key. I then tried to make a bootable USB with High Sierra and the same thing happened.
Essentially when I boot using the options key the only option I can see is to connect to internet and use Internet Recovery. Using internet recovery attempts to install the Lion OS, which then gives me the required components error previously mentioned. I’m a bit confused at this point and don’t know what else to do.
If it matters, I have been using TransMac to make these bootable USB drives because I do not have any other Mac devices to work with. I really need to be able to fix this from a windows PC at this point if possible.
Esta é uma boa pergunta?
