Why am I not getting an output?
My computer was working fine. It's been just 2 days since I built it. Everything turns on but the LEDs of the top fans don't light up and the RGB of the wraith spire cooler doesn't turn on. Also there's no output on my monitor. Kindly help at the soonest time possible. Also when I disconnected my CPU power cable the light on my wraith prism cooler starts to glow up.
Esta é uma boa pergunta?
6 comentários
Hi,
More information is needed to help you.
What is the make and model number of the motherboard, make and model number of the PSU?
Does the motherboard have onboard graphics that you can try if the monitor is connected to a GPU card?
What is the make and model number of the GPU card if there is one installed?
Is the computer booting into the operating system i.e. does the HDD/SSD activity light turn on, blink etc?
Have you tried another monitor if possible?
What have you checked?
por jayeff
The motherboard is Gigabyte B450M Aorus Elite and the SSD/HDD activity light doesn't turn on. I've tried with another monitor and stuff's the same. The GPU is Galax Geforce RTX 2060 6GB.
por Aditya D S
The PSU is CoolerMaster MWE Gold 750W
por Aditya D S
There was no beep from the motherboard.
por Aditya D S
It's either a faulty PSU, CPU or motherboard from what it sounds like judging that having the 8-Pin EPS CPU power connector disconnected lets the motherboard turn on.
Have you checked to make sure the power cables going to GPU and motherboard from the power supply are seated in fully?
I also recommend try clearing the CMOS. You can refer to the motherboard user manual found in the motherboard box packaging on how to do so.
Reseat the Ram modules as well (try only one as well on motherboard) and try other slots to rule out a bad slot or individual ram stick.
Once you have exhausted all troubleshooting options last resort is to do RMA for below:
It's rare for the CPU to go faulty so I would say RMA the motherboard first for warranty return to retailer / seller as I suspect that may be faulty and if that does not work next would be RMAing the power supply.
por Ben
Exibir mais 1 comentário
