Ir para o conteúdo principal
Repair and disassembly information for the second-generation iPhone SE that was announced and released in April of 2020.
240 Perguntas Visualizar todos
Both cameras aren't working after a screen replacement
I’ve successfully replaced the screen of my iPhone SE 2020 after it was cracked. Everything works fine except the camera. The battery was disconnected before I started working on it. I have a feeling it could be from when I transferred the camera from the old screen to the new one. Any ideas?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Disconnect the battery and check the connection to the camera and make sure the pins are not damaged or bent. If they are fine clean the connector with a qtip and alcohol and a soft brush and make sure you have a tight connection.
Esta resposta foi útil?
Pontuação 0
3 comentários:
I'll give that a go. Thanks.
por
Sorry, checked all the connections but still no camera's. Do they need new ones?
por
No I doubt you need new cameras. I would take it to a repair shop and have it checked out.
por
Adicionar a sua resposta
David Bonsu será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 88
