Phone won't charge. Battery says it's overheating but its cold,
I was doing a screen replacement for a client. It's just swapping the motherboard and other small components into a new frame with screen. I had it all done and the phone is saying charging stopped. Temperature is to high and won't charge and the phone is coming up with a notification saying it's overheating. They both are not overheating. If I use the same battery and screen with a different motherboard everything is fine. When installing it a tiny bit of the motherboard chipped off. It's where I was trying to put the two small wires under the motherboard and the edge to hold them down chipped off. There are no contacts or tracers on that piece so it doesn't look like it should be doing this. Anyone have a fix. Thanks
Esta é uma boa pergunta?
